Hey nation,
We are rolling 9.2.1 hard in our county. Some students are having a problem where they can't utilize all the storage space they should have after the update. We are seeing this on 16 GB iPads right now. Even after all Apps are deleted, a large amount (6-8 gigabytes) of space is still registered as being used. When connecting to iTunes, this is seen as "Other".
Did a bunch of Googling and the only solution offered is a full wipe. We keep seeing this more and more so I would like to avoid doing that as the primary solution if possible. Is there a way to connect these iPads to Xcode and see what's really taking up that space? Has anyone seen this before?
Thanks,
Cameron
