Trying to update google chrome via script is anyone implementing this already?
I use a slightly simplified version of this with an ongong policy+recon scoped to a smartgroup whose criteria is
Application Title - has - Google Chrome.app
and
Application Version - not like - put the latest version here
Hope this helps
Carlo
@Andrewpants1 BTW, this is Google's official way of handling updates for Chrome:
Does anyone else use Patch Management for this?
Followed that article from Google and made the value 0 but auto update is still not turned on or states it is managed by the org...I wonder if I am doing something wrong. This is what I have in the plist:
<dict>
<key>updatePolicies</key>
<dict>
<key>global</key>
<dict>
<key>UpdateDefault</key>
<integer>0</integer>
</dict>
</dict>
</dict>
</plist>
Try this script https://github.com/ryangball/chrome-enable-autoupdates
The Chrome for Enterprise Team has published a new kBase on Managing Chrome Browser Updates with Jamf Pro (macOS). This takes advantage of Jamf's Application and Custom Settings Payload.
I just use patch management. It works great. That said, I think Chrome for Mac is 💩
I did upload the plist file in Jamf and deployed it to a test device, but Google Chrome seems to be not reading it as it is still showing up the request to turn on auto updates..
The file gets correctly deployed on the device.
I used the following code:
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<dict>
<key>global</key>
<dict>
</dict>
</dict>
</dict>
</plist>
Any idea on what I am doing wrong?
You Guys Use Google Chrome? Try Microsoft Edge. Much Better then Google Chrome
@jefjam7812 Do you work for Microsoft?
Install Little Snitch, launch Chrome, and then do nothing, do not even load a web page, and watch all the outgoing TCP connections Chrome tries to make. Better yet, block web content in Parental Controls and watch it flip out constantly requesting creds to make outgoing connections.
There are only 2 ways to sanely manage Chrome. 1 - use the built in self update plist payload, or use AutoPKG. We have been using the MDM payload to manage Chrome updates and are results are generally pretty good.
Does anybody have a definitive answer for this? I don't want to set up Google managed accounts or Cloud managed browsers. All of the Google documentation for this suggests I have to use one of those options. I just want to push out a simple plist config that will turn on auto-updates for my existing Chrome user base. Anyone?
@mcantwell See the thread Updates to Google Chrome deployment for macOS - Chrome is now available as a .pkg installer which automatically configures auto updates. Just deploy the package referenced in that post to your environment and you'll be set.
That would be great for new deployments (I am currently using a script to install the latest Universal binary installer), but I don't want to cause potential disruptions by reinstalling Chrome for everybody. Is there a simple guide for turning on auto-updates for Chrome that's already installed? I keep seeing reference to com.google.Keystone.plist for controlling automatic updates. Would that involve just pushing a customized version of this file out to all my computers?
@mcantwell There's some configuration involved, so it's not just pushing a .plist. Here's a Python script you can run via a Jamf Pro policy that should enable auto updates for existing installs: https://github.com/hjuutilainen/adminscripts/blob/master/chrome-enable-autoupdates.py
I say should because Google has a habit of mucking with where the keystone tool lives in the application bundle.
I'm using a script that based on if the Mac is M1 or Intel mac deploys the right installer.
First i created two smart groups that assings the mac to M1 or Intel mac
Then i use Jamf's Patch Management to check for the latest stable version of Chrome.
I then have another smart group called Chrome Not Updated that is set to Patch Reporting: Google Chrome IS NOT Latest Version
Then have 2 policys running once every day at checkin with the scope Chrome Not Updated
One policy for M1 Macs and one for Intel Macs.
This policy then runs a script that downloads the latest stable version of Chrome and installs it.
Script for Intel Macs:
dmgfile="googlechrome.dmg"
volname="Google Chrome"
logfile="/Library/Logs/GoogleChromeInstallScript.log"
url='https://dl.google.com/chrome/mac/stable/GGRO/googlechrome.dmg'
/bin/echo "--" >> ${logfile}
/bin/echo "`date`: Downloading latest version." >> ${logfile}
/usr/bin/curl -s -o /tmp/${dmgfile} ${url}
/bin/echo "`date`: Mounting installer disk image." >> ${logfile}
/usr/bin/hdiutil attach /tmp/${dmgfile} -nobrowse -quiet
/bin/echo "`date`: Installing..." >> ${logfile}
ditto -rsrc "/Volumes/${volname}/Google Chrome.app" "/Applications/Google Chrome.app"
/bin/sleep 10
/bin/echo "`date`: Unmounting installer disk image." >> ${logfile}
/usr/bin/hdiutil detach $(/bin/df | /usr/bin/grep "${volname}" | awk '{print $1}') -quiet
/bin/sleep 10
/bin/echo "`date`: Deleting disk image." >> ${logfile}
/bin/rm /tmp/"${dmgfile}"
exit 0Script for M1 Macs:
url='https://dl.google.com/chrome/mac/universal/stable/CHFA/googlechrome.dmg'
/bin/sleep 10
/bin/sleep 10
In the Intel policy i set the scope to include all Macs in the group Chrome Not Updated and exclude Macs in the M1 group
In the M1 policy i set the scope to include all Macs in the group Chrome Not Updated and exclude Macs in the Intel group
Once the policy is done i use User interactions with a message saying
"Google Chrome is up to date.
Please reboot Chrome at possible time."
All done.
This way i always know that the Macs have the latest version of Chrome and i don't have to touch anything.
Hope someone finds this helpful! 😊
/bin/sleep 10
/bin/sleep 10
/bin/sleep 10
/bin/sleep 10
All done.
My updates with your script stalled out at Chrome version 98.0.4758.102. Here's the updated script I'm using that pulls the latest version:
#!/bin/bash -e
# Apps_Chrome_Update.sh
# Last Updated 2022-March-15 by John Bowman
pkgfile="googlechrome.pkg"
url='https://dl.google.com/chrome/mac/stable/accept_tos%3Dhttps%253A%252F%252Fwww.google.com%252Fintl%252Fen_ph%252Fchrome%252Fterms%252F%26_and_accept_tos%3Dhttps%253A%252F%252Fpolicies.google.com%252Fterms/googlechrome.pkg'
/usr/bin/curl -s -o /tmp/${pkgfile} ${url}
/usr/sbin/installer -pkg /tmp/${pkgfile} -target /
/bin/sleep 10
/bin/rm /tmp/"${pkgfile}"
#!/bin/bash -e
/bin/sleep 10
Thanks for the updated script. It works great!
#!/bin/bash -e
/bin/sleep 10
Thank you John, does your script work for both Intel and Silicon clients?
The installer is from here:
https://chromeenterprise.google/browser/download/#mac-tab
which states that it's for x86 and ARM. I'm guessing that by ARM they mean Apple Silicon.
