So I use AAMEE to make a package and it creates a folder on the desktop. Do i Use the PKG in the folder or do I create a DMG from the folder somehow. If the answer is the second, how does one go about doing that?
-- Experts claim that 72% of all statistics are made up on the spot.
-- Lance L. Lennon
District Technology Director
Eagle Grove Community School District
515-448-4749
Follow these instructions for Casper. The Acrobat 10.1 patch works great as well. You can run it after the install with a policy
http://jamfsoftware.com/kb/article.php?id=274
Patrick Bachuwa
Desktop Engineering Applications Sears Holdings Corporation
Michigan Campus
3000 W. 14 Mile Road
Royal Oak, MIĀ  48073-1717
Phone: 248 637-0350
Patrick.Bachuwa at searshc.com
Use the install pkg
Regards,
Ben.
Hey Lance -
check out this page from the JAMF website:
http://jamfsoftware.com/solutions/adobe-creative-suite/
the PDF you can download there has really great step-by-step instructions. Reading through this should answer your question below, as well as prevent a few other questions from popping up :D
ben janowski
Senior Macintosh Support Technician
Kohl's Mac Support Team
262.703.1396 | benjamin.janowski at kohls.com
That tool will give you a PKG that is ready to deploy.
Matt Lee, CCA/ACMT/ACPT/ACDT
Senior IT Analyst / Desktop Architecture Team / Apple S.M.E / JAMF Casper Administrator
Fox Networks Group
