Unity Web Player installation
  • September 6, 2017
  • 14 views
Hello, I'm new to Jamf and all that goes along with it so please be patient with me. :)
I'm trying to create a package through Composer that will copy and install (through the postinstall script) Unity Web Player.
I haven't a clue about the script to use.
I've tried simply putting the Unity Web Player package into Self Service but I must be doing something wrong as it doesn't properly install onto the student machines.
Any ideas on the post script that I could use to install after the package is pushed out to the machines?
Thank you for any help that can be given.
  • September 6, 2017
Did you open DMG file provided by Unity and placing the "Install Unity Web Player" file into Casper Admin? I believe this is a pkg file so you should be able to use a policy to install.
  • September 7, 2017
Thanks for responding!
I might have mistakenly placed the DMG into Casper Admin instead of carving it down to simply the PKG file.
I'll try that and see if I have better results.
Thank you again for your assistance!
