Hi all,
I've had to take one of the clients off site and we have a managed preference to disable wifi set on it. Is there a way i can disable this so i can use the wifi, while i'm off site?
Hi all,
Go to /Library/Managed Preferences/username. Delete either the specific plist or the whole folder. Log out and in.
Settings should get reapplied next time they log in and talk to the server. So it should work offsite for you.
