script to rename computer name (letter of first name and last name)
  • January 30, 2018
  • 27 replies
  • 191 views
I know there's a number of discussion on it but haven't quite found the correct one. I'm trying to have a policy that will call a script to change computer name based upon users first letter and last name. Here's the workflow:
-User will enroll via DEP. Enter in John Smith
-DEP will look for SplashBuddy (SB) to run.
-SB will do it's thing and will trigger all install packages.
-one of the policies to kick off is to take the information set for the User name and change computer name to jsmith-mbp on the local macbook.
Any help would be appreciated. Thank you
Best answer by boberito
So you'd have to write a script that does that. You could put that script potentially in a payload-free package or a script that runs with a policy.
#gets current logged in user
getUser=$(ls -l /dev/console | awk '{ print $3 }')
#gets named
firstInitial=$(finger -s $getUser | head -2 | tail -n 1 | awk '{print tolower($2)}' | cut -c 1)
lastName=$(finger -s $getUser | head -2 | tail -n 1 | awk '{print tolower($3)}')
computerName=$firstInitial$lastName"+mbp"
#set all the name in all the places
scutil --set ComputerName "$computerName"
scutil --set LocalHostName "$computerName"
scutil --set HostName "$computerName"
boberito
Forum|alt.badge.img+22
  • January 30, 2018
#gets named
  • January 30, 2018
This is what I use with my DEP setup. Not that you can't use underscores "_" in the host name. This is why I have hostname and hostname2. This will also add the mac address at the end in case of duplicates. Occassionally at my school we have same first initial and last name so that prevents duplicates.
Just place the script in a policy and call it using
jamf policy -event yourtrigger
# Computer Naming Script
#Set the hostname
# figure out the user
user=$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
#figure out the user's full name
name=$(finger "$user" | awk -F: '{ print $3 }' | head -n1 | sed 's/^ //' )
# get first initial
finitial="$(echo "$name" | head -c 1)"
# get last name
ln="$(echo "$name" | cut -d   -f 2)"
#Get Mac
mac=`networksetup -getmacaddress Wi-Fi | awk '{ field = substr($3,10,8) }; END{ print field }' | sed s/://g`
# add first and last together
un=($ln"_"$finitial"_"$mac)
un2=($ln"-"$finitial"-"$mac)
# clean up un to have all lower case
hostname=$(echo "$un" | awk '{print tolower($0)}')
hostname2=$(echo "$un2" | awk '{print tolower($0)}')
echo $hostname
sudo scutil --set HostName $hostname2
sudo scutil --set LocalHostName $hostname2
sudo scutil --set ComputerName $hostname
dscacheutil -flushcache
bburdeaux
  • January 30, 2018
We do something similar, but use another AD field to fill in the campus the person is at as well(mapped to the Department field in JamfPro), so we pull the info from the User and Location section using the API.
jssUser=$4
jssPass=$5
jssHost=$6
serial=$(ioreg -rd1 -c IOPlatformExpertDevice | awk -F'"' '/IOPlatformSerialNumber/{print $4}')
username=$(/usr/bin/curl -H "Accept: text/xml" -sfku "${jssUser}:${jssPass}" "${jssHost}/JSSResource/computers/serialnumber/${serial}/subset/location" | xmllint --format - 2>/dev/null | awk -F'>|<' '/<username>/{print $3}')
dept=$(/usr/bin/curl -H "Accept: text/xml" -sfku "${jssUser}:${jssPass}" "${jssHost}/JSSResource/computers/serialnumber/${serial}/subset/location" | xmllint --format - 2>/dev/null | awk -F'>|<' '/<department>/{print $3}')
if [ "$username" == "" ]; then
    echo "Error: Username field is blank."
    exit 1
elif [ "$dept" == "" ]; then
    echo "Error: Department field is blank."
    exit 1
compname=$dept"-"$username"-mac"
/usr/sbin/scutil --set HostName "$compname"
/usr/sbin/scutil --set LocalHostName "$compname"
/usr/sbin/scutil --set ComputerName "$compname"
  • January 30, 2018
@boberito Thank you for the script. It looks good.
  • January 30, 2018
@boberito Great script! Would anyone know how to add to this script so that it can check the type of Mac it is and append the appropriate name?
For John Smith, we use:
JSMITH.PORTABLE for Laptops
JSMITH.DESKTOP for Desktops
Edit: Actually, I'm running into the following error
SCPreferencesSetLocalHostName() failed: Invalid argument
I believe it's because the + symbol is not an accepted character for the Local Host Name?
boberito
  • January 30, 2018
No idea about that error. It's entirely possible the + isn't allowed, or maybe there's a hidden character like a return character or something. I dunno.
sysctl -n hw.model | cut -d "," -f 1 | tr -d '[0-9]_'
That'll give you the model of the computer
Then you'd need some if or case statements to determine if you want it named portable or desktop.
boberito
  • January 30, 2018
And looking at the system preferences, sharing. You'll see the Computer Name has a + but the local network name right under it is the name without the plus.
  • January 31, 2018
I just use a "Smart List" with criteria: Model is like Macbook
( = Macbook, Macbook AIR, Macbook Pro ) = Laptop
Anything else is a Desktop…
So Smart Group: Desktop criteria: Model is not like Macbook
This seems like the simplest way to distinguish between Desktops and Laptops…
( unless you need the criteria in a script as part of some other processing… )
  • May 4, 2018
I was able to use boberito's script, at the top, I edited to display/change computer name as firstname lastname. Not a huge issue but the names are lower case, is there a tweak so that I can get the names displayed first letter is capitalized. Thanks in advance.
  • June 12, 2018
Something like this should work.
firstInitial=$(finger -s $getUser | head -2 | tail -n 1 | awk '{print toupper($2)}' | cut -c 1)
  • March 28, 2019
@tcarlson - what does your script look like now, either with or without proper capitalization (ideally with)? I'm trying to accomplish the same thing.
  • October 15, 2019
I have taken ideas from everyone, but I cannot remove the following error:
Executing Policy Test Computer Name
Running script Computer Name By Hebert...
Script exit code: 0
Script result: SCPreferencesSetLocalHostName() failed: Invalid argument
Rename Successful
My script is:
#gets named
firstName=$(finger -s $getUser | head -2 | tail -n1 | awk '{print ($2)}')
lastName=$(finger -s $getUser | head -2 | tail -n1 | awk '{print ($3)}')
model=$(sysctl -n hw.model | cut -d "," -f 1 | tr -d '[0-9]_')
computerName=$firstName" "$lastName" "$model
localHostName=$firstName"-"$lastName"-"$model
echo $ComputerName
/usr/sbin/scutil --set ComputerName "$computerName"
/usr/sbin/scutil --set HostName "$computerName"
/usr/sbin/scutil --set LocalHostName "$localHostName"
echo "Rename Successful"
  • December 4, 2019
I made a couple changes, see if this works for you.
#gets named
echo $computerName
/usr/sbin/scutil --set LocalHostName "${localHostName}"
sdagley
  • December 4, 2019
@OOBIDUB Use the code block tag (triple back-tick ```) before and after your script to prevent the forum sofwtare from mangling the display.
  • December 5, 2019
Hello,
I made some changes, I included the first letter to be capital and the following letters to be lower case.
#gets named
firstName=$(finger -s $getUser | head -2 | tail -n 1 | awk '{print toupper(substr($2,1,1)) tolower(substr($2,2)) }')
lastName=$(finger -s $getUser | head -2 | tail -n 1 | awk '{print toupper(substr($3,1,1)) tolower(substr($3,2)) }')
computerName=$firstName" "$lastName"'s "$model"
echo $computerName
szultzie
  • March 20, 2020
hi everyone, hoping someone can help. Im looking to do the exact thing as here, name a computer with a user. my issue is that i get _mbsetuser becuase if i run this policy at enrollment thats the user that is logged in. Is there an easy way to wait till a real user logs in before it runs?
My end result is username-serial number as the computer name. My PreStage is authenticating to my AD (other issue with this part right now) but when it works it passes the AD usernaem and creates a local user with the same name. Id like to name the computer the username-serialnumber, so far in testing i am able to run it after a user is set up and logged in and it does what I want, if i let it sit it gives me _mbsetupuser.
This is a script i put together from various Jamf Nation sources =)
I am not great at scripting, but i think maybe a check to see if the user is _mbsetupuser and then wait xx seconds and try again until its not?
##get serial number
computerName=$(ioreg -c IOPlatformExpertDevice -d 2 | awk -F" '/IOPlatformSerialNumber/{print $(NF-1)}')
#set the host name on several places
/usr/local/bin/jamf setComputerName -name "$user-$computerName"
/usr/sbin/scutil --set LocalHostName "$user-$computerName"
/usr/sbin/scutil --set HostName "$user-$computerName"
/usr/sbin/scutil --set ComputerName "$user-$computerName"
/usr/bin/defaults write /Library/Preferences/SystemConfiguration/com.apple.smb.server NetBIOSName "$user-$computerName"
/usr/local/bin/jamf recon
Is there a way to reverse the script for first name last initial?
  • April 26, 2020
Hi @fernandez.payen ,
Building off of @boberito 's script, you can edit the "cut" filter for your desired name requirement.
| cut -c 1
I put an example to show the what the difference would be:
#gets named
firstName=$(finger -s $getUser | head -2 | tail -n 1 | awk '{print tolower($2)}')
lastInitial=$(finger -s $getUser | head -2 | tail -n 1 | awk '{print tolower($3)}' | cut -c 1)
#final computer name using First Name and Last initial
computerName=$firstName$lastInitial"+mbp"
Forum|alt.badge.img+31
  • April 27, 2020
Python 3 method using dscl with plist output and using plistlib to parse the data. You can do pretty much all the string manipulation you would need with native builtins
>>> import subprocess
>>> USER, UID, GID = SCDynamicStoreCopyConsoleUser(None, None, None)
>>> user_path = "/Users/" + USER
>>> cmd = ['dscl', '-plist', '.', '-read', user_path]
>>> proc = subprocess.Popen(cmd, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
>>> out, err = proc.communicate()
>>> import plistlib
>>> plist = plistlib.loads(out)
>>> realname = plist['dsAttrTypeStandard:RealName']
>>> print(realname[0])
Tom Larkin
>>> name_list = realname[0].split()
>>> print(name_list)
['Tom', 'Larkin']
>>> fname = name_list[0]
>>> print(fname)
Tom
>>> print([c for c in fname])
['T', 'o', 'm']
>>> print([c for c in fname][0])
T
Shell is probably a bit more of a simple approach, but using the dscl output you would deal with more structured data
emily
  • May 27, 2021
I realize I'm digging up an old thread but I thought this might help someone who is getting SCPreferencesSetLocalHostName() failed: Invalid argument when trying to set the LocalHostName when changing the computer name. This is due to the local hostname not allowing any special characters. You can do something like the following to strip special characters:
localHostName=$( echo $computerName | tr -dc '[:alnum:] ' )
Then for the line that sets the local hostname use that modified variable instead. So for a computerName of first.last+mbp you'd get a local hostname of firstlastmbp.
howie_isaacks
Forum|alt.badge.img+23
  • September 27, 2021
#gets named
I like this! I modified this a bit to add the initials of the client company, an "M" for Mac, and then the user's first and last initials. These are all separated by a dash... PC-M-HI. Company: Pretend Company  Computer type: Mac User first and last name: Howie Isaacks. I set the "PC-M" to be in all caps, but I wanted everything to be in caps so I changed the command from "tolower" to "toupper ".
howie_isaacks
Here's what I came up with. I tested it on my iMac, and it worked exactly as intended.
#!/bin/sh #Rename the Mac using the first and last initial of the user's name. Before using this script, replace "XX" in line 12 with the client company's initials #Who is the current logged in user? currentUser=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'` echo $currentUser #Generate computer name - Replace "XX" with the client company's initials firstInitial=$(finger -s $currentUser | head -2 | tail -n 1 | awk '{print toupper ($2)}' | cut -c 1) lastInitial=$(finger -s $currentUser | head -2 | tail -n 1 | awk '{print toupper ($3)}' | cut -c 1) computerName=$"XX-M-$firstInitial$lastInitial" echo $computerName #Send the computer name to inventory record scutil --set ComputerName $computerName scutil --set LocalHostName $computerName scutil --set HostName $computerName #Clear the directory service cache then run a current inventory to send the new Mac name to Jamf Pro dscacheutil -flushcache /usr/local/jamf/bin/jamf recon
  • April 13, 2023
#gets named
Hey Boberito - I'm a new Jamf admin and want to create a script to help rename all Macs in our environment.
I want to pull Firstname Lastname asset tag number and MBP to the end of each. I am still trying to figure out where even to start. I was thinking about putting this in a policy.
markopolo
  • April 24, 2025
This script works great if all your users only have two names (first + last) in their directory record. It doesn't work so well for Full Names that contain middle name(s). Any ideas on how to modify it to work with usernames instead, which in our environment is "first.last" (with no middle names)? Our computer naming format is "first initial + lastname + hyphen + last 7 digits of SN".
howie_isaacks
  • April 28, 2025
This should work. I used the Jamf "setComputerName" command to set the computer name. Below it are the scutil commands to set the computer name. I commented out those lines. They are only needed if you're not using the Jamf command to name the computer. If you use scutil, you would want to comment out the line that uses the Jamf command.
#!/bin/zsh jamfBinary="/usr/local/jamf/bin/jamf" # Get last 7 of serial number serial=$(system_profiler SPHardwareDataType | grep Serial | /usr/bin/awk '{ print $4 }' | tail -c 8 ) # Current logged in user currentUser=$(/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }') # First Name firstName=$(dscl . -read /Users/$currentUser RealName | cut -d: -f2 | sed -e 's/^[ \\t]*//' | grep -v "^$" | /usr/bin/awk '{ print $1 }') # Last Name lastName=$(dscl . -read /Users/$currentUser RealName | cut -d: -f2 | sed -e 's/^[ \\t]*//' | grep -v "^$" | /usr/bin/awk '{ print $2 }') # Get first initial firstInitial=$(finger -s $currentUser | head -2 | tail -n 1 | awk '{print toupper ($2)}' | cut -c 1) # Get last initial lastInitial=$(finger -s $currentUser | head -2 | tail -n 1 | awk '{print toupper ($3)}' | cut -c 1) # Generate computer name computerName="${firstInitial}""${lastName}"-"${serial}" # Run Jamf command to name the computer "$jamfBinary" setComputerName "$computerName" # Use scutil to set computer name - comment out if using 'jamf setComputerName' #scutil --set ComputerName "$computerName" #scutil --set LocalHostName "$computerName" #scutil --set HostName "$computerName"
