Turn Filevault off and remove policy from computer.
  • September 14, 2017
  • 23 views
We have a computer that we would like to decrypt the Filevault and do some testing.
I decrypted the computer manually, and added the machine as an exception in the JSS policy, but upon trying to log on it is asking to enable Filevault again. Is there a file somewhere that is causing this?
Best answer by tnielsen
fdesetup disable
this should take care of it. ssh the command to the machine.
fdesetup disable
Awesome. That worked. Thanks.
