Hi folks,
Wondering if anyone has any experience with this. Client had registered their JSS with DEP but it was never going to work, as their JSS was not publicly exposed/it had a private .lan DNS hostname/URL.
So, we changed the hostname, configured internal and external DNS, regenerated the built-in SSL cert, restarted Tomcat, and opened up inbound ports 8443 and 80 to the JSS. Tested it and everything works, both on the local LAN and on the Internet.
Unsuprisingly, trying to activate a DEP-enrolled iPad resulted in an error about "A server with the specified hostname could not be found". So, we logged back into the DEP portal, removed the MDM server and created a new one, with a newly-downloaded Public Key. Downloaded the token file, recreated it in the JSS, and re-scoped everything to the new server in the JSS.
Still getting the "The configuration for your iPad could not be downloaded from xxx. A server with the specified hostname could not be found." Trying to do this from a non-firewalled public internet connection...
Anyone have any thoughts/suggestions/tips/advice? The first-tier JAMF support person I talked to wasn't that experienced with DEP to offer any suggestions, just created a ticket for further follow-up...
