Can't deploy an App
  • November 11, 2018
  • 0 replies
  • 11 views
Hey all, been having issues deploying a specific app called "Flipgrid". What it does is, it just sits installing in JAMF and says "Waiting" on the iPad. If I try to tap on the app, it looks like it's about to install but will have a pop up that it failed and will be given an option to retry or cancel. I tried re-deploying the app, re-added to the mobile catalogue and then re-deploying again and no go, I also tried deploying a different app to this set of iPads and it went through without any problems.
This flipgrid app has also been deployed to other 1500 iPads so I don't think it's an app issue. I could be wrong but in the logs it says "Error managing licenses. ErrorNumber: 9632 , ErrorMessage:Too many recent calls to manage licenses with identical requests" and not 100% sure if this log is pertaining to my flipgrid problem.
Any advice would be greatly appreciated.
