When I try to install a package or send a script to a Mac via Jamf Remote it fails and when I check the log the last entry is "Verifying Computer's Identity..."
I recon'ed the Mac in question, I ran sudo jamf manage and still same error. I rebooted the Mac and still the same issue. I was able to ssh into the Mac using the same credentials the JSS was using and was successful when logging in. Right now the only way to resolve the issue was to do the following:
1. run sudo jamf removeFramework
2. Log into the JSS and delete the Mac in question.
3. Restart the Mac and then re-enroll it into the JSS.
After that I was able to successfully send the package to the Mac via Jamf Remote without it failing.
