Hi @bentoms or anyone else that can help,
I'm having an issue where user's can't reset their password successfully using ADPassMon, the user has a valid kerberos token and line of sight to Active Directory, the machine is connected to the network via cable, I've tried resetting all the ADPassMon settings but have no luck getting this working, I have also tried un-binding and re-binding to the domain and resetting the mac in between attempts.
I have a script which is making my ADPassMon plist as such:
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon accTest -int 0
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon enableKerbMinder -bool true
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon enableKeychainLockCheck -bool true
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon enableNotifications -bool true
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon expireAge -int 90
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon selectedMethod -int 1
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon warningDays -int 14
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon pwPolicy "Our Policy Text"
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon pwPolicyButton "I understand"
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon selectedBehaviour -int 2
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon prefsLocked -bool true
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon passwordCheckInterval -int 1
defaults write /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon runIfLocal -bool true
chown $loggedInUser /Users/$loggedInUser/Library/Preferences/org.pmbuko.ADPassMon.plist
If anyone could shed some light on this that would be helpful, i've tried using this with a previous version and the latest stable version from here
