LDAP Mappings with AD on JSS
  • January 27, 2010
  • 4 replies
  • 22 views
Hello,
I'll most likely open a support ticket for this as all organizations are probably different.
We use Active Directory and I have yet to be able to add a group from AD and grant it access to the JSS. The problem I think is the "Map Member Users To" portion. I believe the attribute should be member, however when testing it never shows an account being a member of a group.
Any suggestions?
![external image link](attachments/3f1c746649654b19b8bc4e7c917d7364)
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • January 27, 2010
If it helps, our settings are practically identical to yours, except that
On 1/27/10 2:17 PM, "Edgar, Ken" <ken.edgar at gmail.com> wrote:
the "Map Member Users to" field is empty for us.
Our Search Base also includes "OU=Groups,". Include this in your Search
Base:
OU=Groups,DC=ad,DC=schoolspecialty,DC=com
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
bentoms
Forum|alt.badge.img+35
  • January 27, 2010
I did this earlier..
Think I needed to tick used distinguished name & create a new LDAP that looked across the root of our domain.
Regards,
Ben.
  • January 27, 2010
William, looks like the map to users field is empty by default... but it didn't seem to work when I did the test if a user is a part of a group. Our groups are also all over the place in different OU's so I can't point to OU=Groups unfortunately.
Thank you
bentoms
  • January 27, 2010
Np.
Good thing it was fresh in my mind.
Regards,
Ben.
