Printer PKG from manufacture
  • May 9, 2017
  • 15 views
Hi Everyone,
I'm at the beginner stage at learning Jamf. I've been trying to add this HP452dn printer but the current macOS Sierra couldn't find the driver for this printer. I was able to find the pkg file on one of the thread in jamf nation.
https://www.jamf.com/jamf-nation/discussions/19209/newest-hp-printers
Do I have to compose this into another pkg file with the printer install or could I add the pkg file that I found and save it to the Casper admin and then add it to my polices?
thanks
mpermann
Forum|alt.badge.img+22
  • May 9, 2017
@Absolem you should be able to use the vendor package as is. Just upload it to your JSS through Casper Admin and then you can deploy the driver to your computers that need it. You will also need to either setup the printer on a computer and capture the setup with Casper Admin or use an lpadmin command to add the printer.
  • May 9, 2017
They way we do it at my school is we have a script that checks the computer for any previously installed printers, removes them, and installs the drivers for each of our printers by pointing to them on our fileserver. Specific sections can be commented out for specifying location the script is being ran at.
# Script to delete old canon copiers and install new KM
# Delete old Copiers
echo "--Current printers"
lpstat -a | cut -d" " -f1 | while read PRTA
do
echo "-"$PRTA
done
lpstat -a | cut -d" " -f1 | grep "HS_Library" | while read PRTB
do
echo "-- Library printer detected attempting to delete: "$PRTB
lpadmin -x $PRTB
sleep 1
done
lpstat -a | cut -d" " -f1 | grep "Office" | while read PRTB
do
lpadmin -x $PRTB
sleep 1
done
lpstat -a | cut -d" " -f1 | grep "Copier" | while read PRTB
do
lpadmin -x $PRTB
sleep 1
done
echo "--Remaining printers"
lpstat -a | cut -d" " -f1 | while read PRTC
do
echo "-"$PRTC
done
# Download Drivers and Install Drivers
cd /Users/Shared
curl -LO http://**ourcasperserver**/CasperShare/Packages/bizhub_554e_109.pkg
curl -LO http://**ourcasperserver**/CasperShare/Packages/bizhub_754_109.pkg
sudo installer -pkg bizhub_554e_109.pkg -target /
sudo installer -pkg bizhub_754_109.pkg -target /
# Setup and Install new KM printer
lpadmin -p NFVHS_Library_Copier -E -v lpd://**printerip**/queue -L NFVHS_Library -P /Library/Printers/PPDs/Contents/Resources/KONICAMINOLTA554e.gz -o printer-is-shared=false -o PaperSources=PC410 -o Finisher=FS534_ZeusX -o KMPunchUnit=PK520-23_ZeusX -o PublicUserAccess=True -o KMDuplex=Single -o KMSection=True
lpadmin -p NFVHS_Office_Copier -E -v lpd://**printerip**/queue -L NFVHS_Office -P /Library/Printers/PPDs/Contents/Resources/KONICAMINOLTA754e.gz -o printer-is-shared=false -o Finisher=FS534SD -o KMPunchUnit=PK520-23 -o PublicUserAccess=True -o KMDuplex=Single -o KMSection=True
rm /Users/Shared/bizhub_554e_109.pkg
rm /Users/Shared/bizhub_754_109.pkg
osascript -e 'tell application "Terminal" to close (every window whose name contains ".command")' &
exit
