Disable Administrator screen unlock for standard logged in user
  • January 28, 2016
  • 0 replies
  • 27 views
Did a bit of research on this and it wasn't completely straight forward so I want to get this out there. Currently tested on 10.10.5 only.
The short of it is as follows:
Export screensaver security settings:
security authorizationdb read system.login.screensaver > /tmp/screensaver
your screensaver file should look like:
<plist version="1.0">
<dict>
    <key>class</key>
    <string>rule</string>
    <key>comment</key>
    <string>The owner or any administrator can unlock the screensaver, set rule to "authenticate-session-owner-or-admin" to enable SecurityAgent.</string>
    <key>created</key>
    <real>442958177.72442001</real>
    <key>modified</key>
    <key>rule</key>
    <array>
        <string>use-login-window-ui</string>
    </array>
    <key>version</key>
    <integer>1</integer>
</dict>
</plist>
Replace
with
<string>authenticate-session-owner</string>
So your xml file looks now like
<dict>
    <key>class</key>
    <key>comment</key>
    <key>created</key>
    <key>modified</key>
    <key>rule</key>
    <array>
    </array>
    <key>version</key>
</dict>
</plist>
Import the settings in using:
sudo security authorizationdb write system.login.screensaver < /tmp/screensaver
Reboot
Resources:
man security
https://derflounder.wordpress.com/2014/02/16/managing-the-authorization-database-in-os-x-mavericks/
https://jamfnation.jamfsoftware.com/viewProductFile.html?fid=374
