unable to distribute Safari 4.0.4
  • January 12, 2010
  • 10 replies
  • 19 views
friends, romans, countrymen: lend me your tech suggestions...
we have not been able, under any circumstances, to successfully
distribute the latest safari via casper. perhaps it's because the new
version of that app utilizes apple's new "flat package" technology.
(right click on the pkg after downloading it from apple and see for
yourself: you can no longer view the package contents...)
we've downloaded both apple pkg's for 10.5 and 10.4, uploaded those
pkg's into casper admin, indexed and set each to be installed with a
dependency for the OS. our policy includes BOTH pkg's so that we've
got one policy regardless of OS, something we do frequently with great
success. this policy is set to kick off at start-up.
however, every time we try to distribute those same pkg's from apple,
we're getting a variety errors of:
+ the app doesn't install although the policy says it has
+ we get the "this path doesn't exist error" we usually get when we've
got bad permissions on our caspershare mount.
and so forth. jamf tech support has, thus far, been stymied as well
but i KNOW i can't be the only one out there with this kind of
experience. talk to me: what have you done to get this app
distributed?
david koff
mac systems admin
the j. paul getty trust
  • January 12, 2010
I have success using the option to install all available updates.
- nick
karthikeyan_mac
  • January 12, 2010
I have installed the same for version of Safari for Leopard and Snow Leopard through Casper policy, it worked fine. Directly created policy with the downloaded pkg from Apple Site. It shows failure logs if the OS version is different is different, in my case it showed failure for Tiger machines.
Regards,
Karthikeyan Marappan
  • January 12, 2010
Have not had issues using Casper 7. What version of Casper are you using?
James Alcasíd | VeriSolv Technologies
Department of Veterans Affairs | Enterprise Infrastructure Engineering
470 L'Enfant Plaza Suite 3100, Washington DC 20024
Office (202) 245-4573
VAITEngineeringCSAppleTier3Support at va.gov
Note:
This message is for the named person's use only. It may contain
confidential, proprietary or legally privileged information. No
confidentiality or privilege is waived or lost by any mis-transmission. If
you receive this message in error, immediately delete it and all copies of
it from your system, destroy any hard copies of it and notify the sender.
You must not, directly or indirectly, use, disclose, distribute, print, or
copy any part of this message if you are not the intended recipient. Any
views expressed in this message are those of the individual sender, except
where the message states otherwise and the sender is authorized to state
them to be the views of any such entity.
P Save Paper ­ Do you really need to print this e-mail?
  • January 12, 2010
If I remember right, one of the Safari updates required a security update
before it would install successfully. Could this be the case?
Brad Rellinger
Technology Specialist
Anthony Wayne Local Schools K-12
brellinger at anthonywayneschools.org << New Email Address
karthikeyan_mac
  • January 12, 2010
Check this, may be helpfull.
http://support.apple.com/kb/HT3949
Regards,
donmontalvo
Forum|alt.badge.img+36
  • January 13, 2010
Please forgive me for jumping in to this thread. I'm curious. If Casper is running on an OS X Server box, why not simply enable SUS and manage it there? This is where I wish JAMF would step in with some best practice recommendations. :):):)
Karthikeyan Marappan <karthikeyan.mac at gmail.com> wrote:
Thanks,
Don
  • January 13, 2010
You could set all your clients to look at your own SUS server on your local network.
Manage it and only put in the Apple updates you want to apply out to your clients.
Then use JSS to run all available updates.
  • January 13, 2010
That's the same way I do it also. I did find however that unless your
Server is 10.6 the Software Update service won't get any updates that
are specific to 10.6.
Patrick Bachuwa
Client Technical Services
Sears Holdings Corporation
Michigan Campus
3000 W. 14 Mile Road
P.O. Box 8073
Royal Oak, MI. 48068-8073
Phone: 248 637-0350
  • January 13, 2010
/indeed.
you will need one on 10.6 and one on 10.5
  • January 14, 2010
Hi David,
Is there any reason why you're not using SoftwareUpdate in OS X Server to
push your packages for this?
I'm pushing out Safari 4.0.4 with no issues at this stage and even though
I've had to re-jig our policies to account for lack of support for OS X 10.6
Server it still proves to be the best option to distribute updates.
Out of interest what version Server are you currently on?
Regards
Anthony Nixon
Mac Technical Analyst
Cancer Research UK
This communication is from Cancer Research UK. Our website is at www.cancerresearchuk.org. We are a charity registered under number 1089464 and a company limited by guarantee registered in England & Wales under number 4325234. Our registered address is 61 Lincoln's Inn Fields, London WC2A 3PX. Our central telephone number is 020 7242 0200.
This communication and any attachments contain information which is confidential and may also be privileged. It is for the exclusive use of the intended recipient(s). If you are not the intended recipient(s) please note that any form of disclosure, distribution, copying or use of this communication or the information in it or in any attachments is strictly prohibited and may be unlawful. If you have received this communication in error, please notify the sender and delete the email and destroy any copies of it.
E-mail communications cannot be guaranteed to be secure or error free, as information could be intercepted, corrupted, amended, lost, destroyed, arrive late or incomplete, or contain viruses. We do not accept liability for any such matters or their consequences. Anyone who communicates with us by e-mail is taken to accept the risks in doing so.
