Hi-
I wanted to post that we have print issues after updating to OS X 10.6.8.
Specifically Xerox docucolor 252’s with an external Fiery Rip.
When you print, it will place the print que on Hold.
Other sites are reporting the issue as well.
http://reviews.cnet.com/8301-13727_7-20074154-263/inability-to-print-after-installing-os-x-10.6.8/
Heads up
Dan De Rusha
We have Sharp copiers with external Fiery RIPs, and I have not experienced
any problems since updating to 10.6.8.
Karl Schoenefeld | IT Department
SGS St Louis | 1035 Hanley Industrial Court | St Louis, MO 63144
Direct: 314-918-3126 | Cell: 314-680-0359
We are seeing the same issues with our Fierys.
I found a fix online that seems to be working on our 3 test machines.
In a nutshell it says to roll back 4 files in usr/libexec/cups/backend
Files are:
socket
dnssd
lpd
ipp
The copies I used are from a 10.6.7 machine.
Here are the threads I found:
http://electro-music.com/forum/viewtopic.php?t=48419
http://forum.support.xerox.com/t5/Printing/Mac-OS-10-6-8-Update-Problems-with-Fiery-Driver/td-p/5668/page/2
https://discussions.apple.com/thread/3137602?start=0&tstart=0
Tom
Tom Tubbiola
Design IT
Ttubbiola at oakley.com
949.900.7705
Anyone tested with Canon CLC's?
Regards,
Ben.
Tested on Canon 3380, CLC5151 and C1 ImagePress.
All good!
Regards,
Myron
Fiery or Creo RIP? Is duplexing still working? Is page orientation OK? Just two things reported by our guinea pigs...er...our testers. :)
Fiery RIP, Duplexing and page orientation working fine...
