FREAK vulnerability
  • March 10, 2015
  • 17 views
Anyone have an extension attribute or something that can tell if the security patch that was applied yesterday to fix the FREAK vulnerability has been applied or not?
Best answer by adkinsan
We are using the OS build number within the Operating System criteria to build smart groups:
10.8.5 = 12F45 (bad), 12F2501(good)
10.9.5 = 13F54 (bad), 13F1066 (good)
10.10.2 = 14C109 (bad), 14C1510 (good)
  • March 10, 2015
  • March 10, 2015
Good idea. Thanks
