Time Zone on iPads
  • February 9, 2016
  • 5 views
Is there a way to set Time Zone on iPad devices. The problem is that when iPad is initially set up even though the Location services are enabled but the iPad is still stuck on Los Angeles unless you go inside and change it to Manual and your local time zone. This is weird behaviour which requires a fix.
1 reply
  • February 10, 2016
Might take a restart of the device to get that updated. We were turning on Location Services as part of the device set up, but usually switching Wi-Fi from one SSID to another at the same time. That would cause the time to not update. It might get sorted out eventually as long as you have location services on and time set to auto.
