"Password for root on localhost" stopping Casper Remote push.
  • April 3, 2017
  • 33 views
Folks:
A few times lately we've had Casper Remote stop in mid push with this error. JSS says it's in management, recently inventory updated and checked in recently. I can run Recon on it remotely and I can SSH to it as root and navigate around so I know my root account on the Mac is all right. Once SSH'd to it I can run jamf manage:
MRMIOMP1125:~ root# jamf manage
Getting management framework from the JSS...
Enforcing management framework...
Checking availability of https://vrmiblrapp09.rci.rogers.ca:8443/...
The JSS is available.
Enforcing login/logout hooks...
Enforcing scheduled tasks...
Creating launch daemon...
Creating launch agent...
MRMIOMP1125:~ root#
And the log says:
MRMIOMP1125 (792)
Sending Wake On LAN command...
Opening SSH Connection to 10.10.110.82...
Authenticating...
Successfully authenticated.
Verifying Computer's Identity...
The MAC Address has been verified.
Checking Operating System Version...
Running Mac OS X 10.9.3 (13D65)
Verifying /usr/local/jamf/bin/jamf...
/usr/local/jamf/bin/jamf is current (9.96)
Verifying /usr/sbin/jamf...
/usr/sbin/jamf does not exist.
Verifying /Library/Preferences/com.jamfsoftware.jamf.plist...
Preparing Policy...
Executing Policy 2017-04-03 at 11:49 AM | scott.beach | 1 Computer
Mounting MRMIBLRXSRV01 to /Volumes/CasperShare...
Copying minolta_bizhub_C368_109.pkg...
Installing minolta_bizhub_C368_109.pkg...
Successfully installed minolta_bizhub_C368_109.pkg.
Mapping Printer OMP_11...
Password for root on localhost?
Does anyone have any thought?
Thanks very much.
- Scott
Best answer by ScottyBeach
Never mind. I figured it out. It was something bad in the printer list or a CUPS config. I "reset Printing System" and tried again and it worked fine. Nothing to do with the error presented at all.
Next time more testing and less typing. Hope it helps someone else.
  • April 3, 2017
Further - I can get packages to it but it fails on a printer configuration in case that's any help. I think I'll test that printer config elsewhere as a control test.
  • April 3, 2017
