I am seeing the same thing. I have done this process successfully before but it seems I can't now. I do know that there is at least one issue with configuration profiles concerning the application of wireless settings. It is possible that there are more problems with this system. I am inclined to avoid configuration profiles until 9.23 is rolled out.
We were having a similar issue. After contacting support, running the command below on the plist file then allowed the converted file to be uploaded without issue.
sudo plutil -convert xml1 /path/to/com.someplist.plist
just seeing this as well :(
im also getting this when trying to upload a config profile using mcxToProfile
Also i have a config profile in my jss and when i try to remove a smart group from the scope i can see the the red arrow :(
You're not holding your mouth right, or you're standing on the wrong foot.
In all seriousness, it's picky. The plist you're uploading should be named to match the preference domain. Also, no binary plists.
Erm..sorry I don't understand your wit I'm afraid.
No I have been doing this for a very long time!
This is Defect D-005920
I get this when trying to upload a config profile which uploaded or modify a config profile setting already in the Jss and all was fine prior to jss 9.22
Please note I never upload a plist. I create my configuraion profiles the fantastic mcxToprofile.
*please note I didn't waste a lot of time for a change because I asked straight away about checking the defects.
@bentoms, have you upgraded past 9.23 and are still having these issues?
@pat.best, we're still on 9.22.
We might hold back until 9.3 tbh.
"Custom" Config Profile could mean two things.
I take it @bentoms is doing what I'm talking about: the Custom payload, which is where you upload a plist containing your settings. I've gotten this to work in 9.x, but I'm not sure if it was 9.22, and even when it did work, it took several attempts.
@tkimpton you are referring to a Config Profile you prepared by hand/tool (aka, "custom"), which is a different workflow (though it may well be affected by the same defect).
@JPDyson, yep. that was what I meant.
After reading this post yesterday and through trial and error got the process down. I explain it all in here for any n00bs out there: http://flyingtoaste.rs/2016/05/deploying-google-chrome-preferences-in-casper/
