10.6 Image with Update to 10.6.2
  • November 16, 2009
  • 22 views
stevewood
Forum|alt.badge.img+38
I am trying to create a 10.6.2 image by using the "build train" method in
7.1. I have a 10.6 "drop in box" DVD from a MacPro that I have created a
dmg of and added to Casper. I have told Casper it is an Apple installer. I
have added the 10.6.2 Combo updater to Casper. Here's what I've tried:
- Compile a configuration with JUST the 10.6 dmg -> machine installs
properly
- Delete that config, add the 10.6.2 Combo Updater and Compile -> machine
installs JUST the 10.6, 10.6.2 does not install, no errors in jamf.log
- Delete that config, add 10.6.1 updater and compile -> Machine installs
10.6.1
- Delete that config, add 10.6.2 (so 10.6 -> 10.6.1 -> 10.6.2) and compile
-> machine installs 10.6.1 but does not install 10.6.2
Has anyone else seen this or tried this?? I can move to installing 10.6.2
as a policy, but I really didn't want to have to do that.
Any ideas are welcome.
Thanks everyone.
Steve Wood
Director of IT
swood at integer.com
T 214.758.6813 | F 214.758.6901 | C 940.312.2475
  • November 16, 2009
I think someone else is having the same problem over on the Mac Enterprise mailing list, but not in Casper:
  • November 17, 2009
Seeing this exact same behavior. Anyone have any suggestions?
Tried both the 10.6.2 Combo Updater as well as applying the regular
10.6.2 update after the 10.6.1 update. No luck either way during
imaging. I end up with 10.6 or 10.6.1 depending on the method.
Any suggestions would be greatly appreciated.
Thanks,
Bob
