Can I check anyone using webdav nav with multiple created with different app configuration?
Example.
Webdav Nav+ (Prep)
Webdav Nav+ (Year 1)
this been assign to different group and different network folder.
I have issue with using this method and it causes the group been pushed wrongly. Prep been pushed with Year 1 command/groups.
Ignore this post... have used back my previous thread.
https://jamfnation.jamfsoftware.com/discussion.html?id=17351
