Hello,
I need a daily report. Our security team want a daily report like this. Does Last users has admin rights? How can i do that? I need your help.
Thank you.
Hello,
Thank you.
You could run a script once a day to try and work out if the logged in user or last user has admin rights... Something like the following will give you a skeleton, though it's far from perfect.
# Logged in user
User_Name=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
if [ -z $User_Name ]; then
	# Mostly will return the last logged in user
	User_Name=$( last -1 | awk '{print $1}' )
# Members of the local admin group
Who_is_Admin=`dscl . -read /Groups/admin | grep GroupMembership`
# Check if the name is in the group
Admin_Exists=`echo $Who_is_Admin | tr " " "\\n" | grep $User_Name`
if ! [ -z $Admin_Exists ]; then
	echo $User_Name was an admin
# Logged in user
Commands are working but how can i report the answer?
So the best answer would probably be to send the info to a log server or a network share, in either case you would need to get the computer name within code. Jamf has extension attributes that could hold this info, but they are not updated once a day... If this information is being gathered for non-Macs you may want to put the info in the same place...
