How To Allow Site Admins Access to Create SCEP Config Profiles
  • May 21, 2025
  • 48 views
RCRC74
At the moment, site admins are not able to create or edit any configuration profiles with the SCEP payload, when an existing one is selected or created by a Site Admin, the page just loads the spinning loading wheel and finally errors out after some minutes. Is there a permissions setting that needs to be selected for this to work for Site Admins? Full admins work without issue, thanks.
howie_isaacks
Forum|alt.badge.img+23
  • May 22, 2025
In Settings - System - User accounts and groups, when you go into a specific user or group, you can go to Privileges - Jamf Pro Server Objects and give the appropriate permissions. I encourage you to test the new privileges before giving them to everyone.
RCRC74
  • June 3, 2025
The response to the case from Jamf is the following:
We believe that we are running into a known issue. PI103709: Cannot create or access configuration profile with SCEP payload while inside a Jamf Pro site
I will be waiting for a solution, for now Site Admins will not be able to configure SCEP payload configuration profiles within a Site realm, they can only be configured by a full admin within the Full Jamf Pro realm selection from the drop down.
howie_isaacks
  • June 3, 2025
That's annoying. My heart sinks every time I hear "PI" or "product issue" from Jamf.
