Bomgar Canned Scripts
  • June 12, 2018
  • 18 views
KyleEricson
Has anyone tried using this
I have tried a simple command like sudo jamf recon but it opens terminal in the remote session and asks for a password. I would rather do an Applescript or embed the creds some how.
  • June 12, 2018
We use alot of canned scripts but we are pretty much a windows shop.
KyleEricson
  • June 12, 2018
@miregan Can you share an example script. I want to know how you would call a powershell script.
  • June 19, 2018
We aren't using Powershell scripts within bomgar. We primarily use cmd files or executables.
