I'm having an issue when creating pkg files and then putting them into Casper Admin 9.01. When I attempt to run them it is telling me that there is no package in the specified zip file even though I have checked it numerous times and the pkg file is in the zip. The distribution point that it is deploying off of is an AFP share.
Page 1 / 1
    I had the same issue. Only way I could find to get around this issue was to make a DMG of the pkg. That seemed to work fine.
