Adobe Acrobat 2017 Serial Number
  • April 26, 2019
  • 475 views
How can I set the serial number for Acrobat 2017 upon install from Self Service? When installing from the desktop the installer asks if you are using a Named User License or if you have a Serial Number. If you choose Serial Number, then you can enter it and it will be licensed with that serial number. However if I install the package through Self Service it just takes the default of Named User License and after the install is finished, the application asks the user to login with their AdobeID and does not prompt for serial.
How can I get the Self Service installer package to use our Adobe Acrobat 2017 serial number?
1 reply
  • April 26, 2019
Not sure if this will work on Acrobat 2017, I think it works on DC
https://helpx.adobe.com/acrobat/kb/how-to-Re-Serialize-Acrobat-using-the-APTEE-tool.html
