Firefox Auto Updates
  • June 4, 2018
  • 8 views
I see some older threads about turning off Firefox auto updates, yet I'm curious what people are currently using?
I'm starting the process of moving from 52 ESR to 60.
Currently I just delete the updated from the package yet that gives clients and error if I don't push the latest version in time...
Thanks for any help.
1 reply
  • June 4, 2018
@llitz123 using the following from Ala Siu's blog. We have a new security initiative to disable autofill/block password fields,I was able to add those settings in the same file
blog
