Microsoft OneDrive - AutoConfigure/AutoLogin
  • October 30, 2018
  • 7 replies
  • 307 views
We are looking to find a way to have OneDrive Configured as the user at Initial Login.
On A PC, when a Domain User Logs In, OneDrive automatically gets Logged in as the Users O365 OneDrive For Business, we are trying to replicate this one MAC's
  • November 26, 2018
I am also wondering how this is done. The only thing I can think of is somehow utilizing NoMAD or Jamf Connect (Azure AD login) to achieve this. A normal AD login for Mac problem won't be able to achieve this.
rickgmac
  • November 27, 2018
From Memory they discussed this at the managing office session at JNUC 2018.
It can be done from a config profile, or it is coming very soon.
  • January 29, 2019
The Redirection part i now do in a Script.
Variable 4 is The OneDrive Folder Name. eg OneDrive for Business yourcompnyname
Variable 5 is whether to simply "Report" or take "Action"
# Description
# Script to Check and/or Modify Users OneDrive Settings
#   Setting Variables
UserName="$3"
ODFolderName="$4"
Act=$5
Action=$(echo $Act | tr “[A-Z]” “[a-z]”)
ODFolder="/Users/$UserName/$ODFolderName"
Desktop=$(ls -n "/Users/$UserName/" | grep "Desktop" | awk '{print $9,$10,$11,$12,$13,$14}')
Documents=$(ls -n "/Users/$UserName/" | grep "Documents" | awk '{print $9,$10,$11,$12,$13,$14}')
ExitCode=0
# Begin Processing
# Checking If Action Variable has been set
# Outputting a Blank Line for Reporting Purposes
echo
if [ "$Action" == "report" ]
    then
        echo
        Echo Script Action is set to Report Only
        if [ "$Action" == "action" ]
            then
                echo
                Echo "Script Action is set to Take Action if needed"
            echo
            echo "Report / Action Variable Not Set For This Script"
            echo
            Echo 'Ending Script "ZZ 17 - Global Settings - OneDrive Settings Script" '
            exit 1
echo
echo -------------------------------------------------------------------------------
echo
# Checking If OneDrive Folder Exists
echo Checking if OneDrive Folder Exists
if ! [ -d "$ODFolder" ]
    then
        echo
        echo Folder '"'$ODFolder'"' Does not exist.
        echo OneDrive Not Set Up For This User.
            then
                echo
                exit 1
            then
                echo
                echo No Actions set for this scenario
                echo
                exit 2
        echo
        echo Folder '"'$ODFolder'"' Exists.
        echo OneDrive must be Set Up For This User.
        echo Continuing Checks
        echo
        echo
# Checking If Desktop Folder in OneDrive
        echo "Checking Existence of Desktop Folder in OneDrive"
        if [ "$Desktop" == "Desktop -> $ODFolder/Desktop" ]
            then
                echo
                echo Desktop Folder is a Symlink to..
                echo $ODFolder/Desktop
                echo Desktop Redirection into OneDrive must be Set Up For This User.
                echo
        if [ "$Desktop" == "Desktop     " ]
            then
                echo
                echo Desktop is an Actual Folder, Desktop Redirection into OneDrive must not be configured
                    then
                        echo
                        ExitCode=3
                    then
                        if ! [ -d "$ODFolder"/Desktop ]
                            then
                                echo
                                echo OneDrive Folder '"'Desktop'"' Does not exist.
                                echo OneDrive Desktop not Set Up For This User.
                                echo
                                echo Moving Desktop Files and Folders into OneDrive
                                mv "/Users/$UserName/Desktop" "$ODFolder"
                                echo
                                echo Creating Desktop Link into OneDrive Folder
                                ln -s "$ODFolder"/Desktop "/Users/$UserName/Desktop"
                                echo
                                echo "Setting Permissions on Desktop Link to OneDrive"
                                chown -R $UserName "/Users/$UserName/Desktop"
                                chmod -R 755 "/Users/$UserName/Desktop"
                                echo
                                echo "Setting Permissions on Desktop Files and Folders in OneDrive"
                                chown -R $UserName "$ODFolder"/Desktop
                                chmod -R 755 "$ODFolder"/Desktop
                                echo
                                echo
                                echo OneDrive Folder '"'Desktop'"' Already Exists but is not linked.
                                echo
                                echo Copying Desktop Files and Folders into OneDrive
                                cp -R "/Users/$UserName/Desktop" "$ODFolder"
                                echo
                                echo Moving Desktop Files and Folders to Desk-Old, Just Incase.
                                mv "/Users/$UserName/Desktop" "/Users/$UserName/Desk-Old"
                                echo
                                echo Hiding Desk-Old, so it does not get used.
                                chflags hidden "/Users/$UserName/Desk-Old"
                                echo
                                echo "Setting Permissions on Desk-Old"
                                chown -R $UserName "/Users/$UserName/Desk-Old"
                                chmod -R 755 "/Users/$UserName/Desk-Old"
                                echo
                                echo
                                echo
                                echo
        echo
# Checking If Documents Folder in OneDrive
        echo "Checking Existence of Documents Folder in OneDrive"
        if [ "$Documents" == "Documents -> $ODFolder/Documents" ]
            then
                echo
                echo Documents Folder is a Symlink to..
                echo $ODFolder/Documents
                echo Documents Redirection into OneDrive must be Set Up For This User.
                echo
        if [ "$Documents" == "Documents     " ]
            then
                echo
                echo Documents is an Actual Folder, Documents Redirection into OneDrive must not be configured
                    then
                        echo
                        ExitCode=4
                    then
                        if ! [ -d "$ODFolder"/Documents ]
                            then
                                echo
                                echo OneDrive Folder '"'Documents'"' Does not exist.
                                echo OneDrive Documents not Set Up For This User.
                                echo
                                echo Moving Documents Files and Folders into OneDrive
                                mv "/Users/$UserName/Documents" "$ODFolder"
                                echo
                                echo Creating Documents Link into OneDrive Folder
                                ln -s "$ODFolder"/Documents "/Users/$UserName/Documents"
                                echo "Setting Permissions on Documents Link to OneDrive"
                                chown -R $UserName "/Users/$UserName/Documents"
                                chmod -R 755 "/Users/$UserName/Documents"
                                echo
                                echo "Setting Permissions on Documents Files and Folders in OneDrive"
                                chown -R $UserName "$ODFolder"/Documents
                                chmod -R 755 "$ODFolder"/Documents
                                echo
                                echo
                                echo OneDrive Folder '"'Documents'"' Already Exists but is not linked.
                                echo
                                echo Copying Documents Files and Folders into OneDrive
                                cp -R "/Users/$UserName/Documents" "$ODFolder"
                                echo
                                echo Moving Desktop Files and Folders to Doc-Old, Just Incase.
                                mv "/Users/$UserName/Documents" "/Users/$UserName/Doc-Old"
                                echo
                                echo Hiding Doc-Old, so it does not get used.
                                chflags hidden "/Users/$UserName/Doc-Old"
                                echo
                                echo "Setting Permissions on Doc-Old"
                                chown -R $UserName "/Users/$UserName/Doc-Old"
                                chmod -R 755 "/Users/$UserName/Doc-Old"
                                echo
                                echo
                                echo
                                echo
echo
exit $ExitCode
szultzie
  • April 18, 2019
Hi @HNTIT , So im looking at your script, and it looks liek somthign i need for our environment.
Im not a big scripter so i had a few questions, How does $3 variable get populated?
Is this designed to run automatically on each users log in?
At first i need a EA to check to see if the one drive folder exisits for a user and report on it, is there a way to midify this script to do that?
-Peter
  • May 29, 2019
We have taken some of your script and added it to our MacOS OneDrive KFM tool. Thank you.
https://github.com/synapsepd/MacOS-OneDrive-KFM
  • December 12, 2019
Thanks for the script.
Works like a charm.
I changed the Username variable.
$3 picks the Jamf connect username including @company.com
So I use: UserName=$(/usr/bin/stat -f%Su /dev/console)
Still the question remains: How do you configure Automatic login?
  • December 12, 2019
Take a look at (https://docs.microsoft.com/en-us/onedrive/deploy-and-configure-on-macos)
