Enable Guest Account on AD joined Mac
  • September 18, 2020
  • 46 views
Hi all,
my question:
how do i activate with CLI the guest account on a macOS Catalina that has an AD join?
i had tried with:
defaults write /Library/Preferences/com.apple.loginwindow.plist GuestEnabled -bool YES and
dscl . -create /Users/Guest
on the login window I see the user and password window.
I type guest and enter but the login fails
any idea?
  • September 21, 2020
Hi @ivanlovisi ,
is there a hidden Management Account? That was the problem why the guest user was not displayed on my devices.
my script:
!/bin/bash
defaults write /Library/Preferences/com.apple.loginwindow GuestEnabled -bool TRUE
show Guest Account in the Login Window
defaults write /Library/Preferences/com.apple.loginwindow Hide500Users -bool FALSE
Hide Management Account from the Login Window
dscl . create /Users/MANAGEMENTACCOUNTNAME IsHidden 1
Does that work for you?
  • August 24, 2021
Ran into this issue myself.. modifying the OS version check in the following script got it working for me in Big Sur (11.5.2):
https://github.com/sheagcraig/guestAccount/blob/master/guest_account
