LDAP Attribute Mapping - Extension Attribute
  • March 24, 2017
  • 4 replies
  • 66 views
Hi all
I'm trying to understand the process involved in obtaining LDAP user attributes with using Extension Attribute.
I can see the option LDAP Attribute Mapping, should it just be a case of adding the attribute name that i want to report on or are there more steps involved ? (as that's not working)
We have an LDAP server and correct mappings in the JSS, and inventory collection is set to Collect user and location information from LDAP.
There are a couple of attributes i want to report on, i'm getting the names from Directory Utility;
in the /All Domains Node/; dsAttrTypeNative:memberOf
in the /Contacts/ Node; dsAttrTypeNative:msRTCSIP-PrimaryUserAddress
any pointers would be greatly appreciated
Best answer by danny_hanes
I am working on this now actually, and I have been using this list of LDAP attributes. You just type the attribute you want in the box and hit save. Then update your inventory on a machine and it should populate. This is of course assume that you have a user associated with that machine. You can verify that by looking at the User and Location section on the computer record.
  • April 6, 2017
  • April 10, 2017
Thanks @dhanes
I Just tested with the Mobile attribute and that works, i think i may have been using incorrect format
These 2 work to see if Skype for Business has been configured for the user.
msRTCSIP-UserEnabled
Thanks again!
  • June 2, 2017
what is the string for description
  • January 16, 2018
just tried this with
data type: integer
Input type: LDAP attribute mapping
LDAP attribute: 512 (514 for disabled)
did recon and recon -endusername $3 and it comes up with only a blank field
