Software license tracking.
  • September 15, 2009
  • 3 views
Forum|alt.badge.img+19
Two part question.
1) How do you all track track your software serial numbers? Do you use the Licensed Software feature in Casper?
2) If you are using the Licensed Software feature in Casper... and you had 100 individual Quicktime Pro Serial numbers... can you import them all at once or do you have to create each entry one at a time?
1 reply
I use keyserver
Cross
