Has anyone successfully install iLife'09 using Casper?
I would like to have the ability to install all apps or just some of them.
What would be the best approach?
Thanks
Stephane
You're invited to read and comment on Landor's blog:
http://landor.com/blog
Stephane Brau
Regional Technology Manager
Landor Associates
44 rue des petites écuries
75010 Paris
France
Phone +33 (0) 1 53 34 31 98
Fax. +33 (0)1 53 34 31 11
http://www.landor.com
stephane.brau at landor.com
De : James Alcasid <james.alcasid at va.gov>
Date : Mon, 21 Sep 2009 10:58:55 -0400
À : "Frye, Jim" <jim_f at usevs.org>, <casper at list.jamfsoftware.com>
Objet : Re: [Casper] Rebooting to a blinking ? icon
Jim,
What OS version did the the new MacBooks ship with and what OS version are
you imaging with? Do you already have MacBooks of this type in production?
Could be hardware failure as mentioned but considering that there is the
same effect with multiple machines and the same process applied and assuming
they booted and worked out the box I think it might be image.
James Alcasíd, ACSA | VeriSolv Technologies
Department of Veterans Affairs | Enterprise Infrastructure Engineering
470 L'Enfant Plaza Suite 3100, Washington DC 20024
Note:
This message is for the named person's use only. It may contain
confidential, proprietary or legally privileged information. No
confidentiality or privilege is waived or lost by any mis-transmission. If
you receive this message in error, immediately delete it and all copies of
it from your system, destroy any hard copies of it and notify the sender.
You must not, directly or indirectly, use, disclose, distribute, print, or
copy any part of this message if you are not the intended recipient. Any
views expressed in this message are those of the individual sender, except
where the message states otherwise and the sender is authorized to state
them to be the views of any such entity.
