font?
  • September 23, 2009
  • 5 views
Does anyone know what the "Jamf" font is? Or, at the least, one that's close (if it's a licensed font).
j
Jared F. Nichols
Desktop Engineer, Infrastructure & Operations
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
1 reply
  • September 24, 2009
well I think the typeface that JAMF uses was just designed for
them-either that or I really don't know what it is. The closest typeface
would probably be Churchward:
http://new.myfonts.com/fonts/blhd/churchward-design/regular/ (or bold,
probably better)
The way the letters are terminated, you can there are glaring
differences, but if you just want something close, that would probably
be my pick.
lauren
LAUREN NICHOLAS
User Support Analyst - Hurd (South) Campus
Center for Information Technology - CIT
Moravian College
ph. 610 861 1633
lpnicholas at moravian.edu
