Good Morning,
Is there anyway Casper remote can send messages to the user without using
the reboot tab.
Thank you,
WILLIE PEREZ
SCHAWK!
T 905.219.1600
D 905.219.1658
M 416.435.1085
wperez at schawk.com
1620 Tech Ave
Mississauga, ON L4W5P4 CANADA
schawk.com
Schawk invites Industry Thought Leaders to participate in BRANDSQUARE, a
one-of-a-kind, exclusive online marketing community. Visit
http://brandsquare.com
Please consider the impact to the environment and your responsibility toward
protecting it before
printing this e-mail.
On the advanced tab use the Run Command line and the JAMF binary on the
system. Enter the following into the Run Command line:
/usr/sbin/jamf displayMessage -message 'Hello!'
Craig E
You could always use a script to call the display message verb in the jamf
binary, but it does the same thing as what you get with using the reboot
tab.
Having the script way would allow you to display the message before the rest
of the job starts which has been discussed on the list before so you might
want to have a gander at the archives as well.
John
-- John Wetter
Technology Support Administrator
Educational Technology, Media & Information Services
Hopkins Public Schools
952-988-5373
you can install growlnotify
get it from the growl website and install or you can use my built pkg attached
i then use a script to send messages, attached is the script
$4 = Application to use the icon from, for example Finder , Self Service, Terminal etc $5 = Title of the window message $6 = Message to display
this window is sticky so will remain open till the user clicks it,, u can also add -w to make the script wsit till the user clicks in case you need them to accept anything before installing an app etc
Criss
Criss Myers
Senior Customer Support Analyst (Mac Services)
Apple Certified Technical Coordinator v10.5
LIS Business Support Team
Library 301
University of Central Lancashire
Preston PR1 2HE
Ex 5054
01772 895054
Forgot the caveat...only works when a user is actually logged in.
But then I was thinking why not use the reboot tab? If you don't want it to
reboot just set both of the options to Do Not Reboot, use the message box at
the bottom and check the box to display message even if not rebooting.
Does essentially the same thing.
Craig E
i add this script to all my self service so users got notice when they have installed apps etc
Criss
Criss Myers
Library 301
Preston PR1 2HE
Ex 5054
01772 895054
This looks awesome. I'm definitely going to experiment with this.
Jared F. Nichols
Desktop Engineer, Infrastructure & Operations
MIT Lincoln Laboratory
244 Wood Street
781.981.5436
well i thought so which is y i mentioned it yesterday
install Growl
then install growlnotify, i built a pkg for each one, i can send if you like
has great advantages i can see
you can script with -w to pause until the user clicks
so rather than use jamfs reboot u could script the message with a -w and then a reboot in the script after, once the user closes the box it reboots
u can customise the icon and title and dont think theres a limit on text
and it displays in what ever style the user has set from growl,
i also use Hardware growler, which shows when a device is attached, when its mounted and ejects, so you know the disk has ejects so you can unplug it, also show then you have an ip address or have lost and ip address, plus loads of apps work with it
Criss
Criss Myers
Library 301
Preston PR1 2HE
Ex 5054
01772 895054
