Filevault - Boot Partition Encrypted
  • January 21, 2013
  • 9 replies
  • 51 views
How would you go about finding out why casper is only reporting: Boot Partition Encrypted vs All Partitions Encrypted, when I go into the inventory, I only see one drive and it says 100% encrypted.
Best answer by rich.trouton
To follow up on that, I've got an extension attribute available here:
https://github.com/rtrouton/rtrouton_scripts/tree/master/rtrouton_scripts/filevault_2_encryption_check
  • January 22, 2013
FV1 vs FV2?
  • January 22, 2013
I've seen this in cases where an external disk was also plugged into the system while it was inventoried. I've never seen this occur when there was only one local disk. Do you have network drives that mount? I wonder if there was a mounted network disk which may make FileVault report "boot disk encrypted" instead and a network disk wouldn't show up in the "hard drives" section in the Casper inventory.
  • January 22, 2013
Bootcamp or Grub loader installed? Just started evaling casper this last week and the first thing I deployed was filevault 2 to a set of test machines. The one with bootcamp came back as "Boot Partition Encrypted". Since it will not be able to of course encrypt the other partition I would assume it comes by as only the boot partition was encrypted and not the rest.
  • January 22, 2013
This is a great point. Technically speaking, FV2 is a volume-based encryption tool, not full disk. However in most cases there is only 1 volume anyway...
  • January 22, 2013
Found it to be the users that had external HD'S plugged in.. Even though the drives were encrypted casper reported it as boot partition encrypted, instead of all..
  • January 22, 2013
I suggest you build your own Extension Attribute (or grab one out there already) to report on FileVault 2 status. Don't rely on the one built into Casper. its hard to pull any actual report on the state of encryption with it.
Forum|alt.badge.img+33
  • January 22, 2013
  • January 22, 2013
Awesome thanks Rich! Great blog by the way
Forum|alt.badge.img+19
  • January 22, 2013
ooooh, that's a NICE fv2 ea! thanks, rich!!
