Hello,
I've been trying for a while to get the Epson USB Display app captured to get into Self Service. I've resigned myself that it probably isn't capturable via Composer, so my next option was going to be to create a package that puts the installer app into Applications and run it from a script. Well, on our student Macs we get the error
You don't have permission to use the application "USB Display Installer"
I have checked all of my Restricted Applications (we've only got a handful), and verified that I can run any app that is in the /Applications/ directory. I also noticed that when I run it from Terminal, the install copies to the /var/tmp/ folder, so I added that to our list of allowed directories in our student restrictions, but still get that error.
When running from Terminal using open /Applications/USB Display Installer.app
, I also get the message
LSOpenURLsWithRole() failed with error -10810 for the file /var/tmp/TB_<cut out long ID>/USB Display Installer.app
So far nothing I have turned up helps. I have tried running this with sudo, tried playing with permissions, tried putting it in various other directories, but still get the same errors. Is this just one of those apps that I will not be able to get onto our student Macs? We can log in with our admin account and select the option to "Allow Once", bu that isn't really feasible for 2000 devices.
In case you were wondering, the software can be downloaded from: Epson PowerLite 1750
Thanks for any insight you can provide,
Tim Musa
