Export the Network Segments
  • October 28, 2014
  • 11 views
ImAMacGuy
Forum|alt.badge.img+23
We have about 180 network segments in our environment with more added constantly. Is there a way to export our current list of segments to compare against? I noticed the Subnet Importer plugin, but it despite the "export" button, it only imports from CSV to the JSS, not "export" from the JSS to CSV.
  • October 28, 2014
I'd look at the API for that. It shows all Network Segments, names and starting/ending IP ranges. Might take a little bit of digging to get it formatted correctly, but it should be possible to "export" them out to a csv formatted file.
  • October 28, 2014
The API Endpoint would be as follows:
https://jss.example.com:8443/JSSResource/networksegments
It returns by default in XML format and spits out the segment id, name, starting address and ending address.
Once you get the results, if you are looking for a one time export then you could use something like http://xmlgrid.net/xml2text.html
