Yea, basically, how can I run a sudo command on machine startup?
You could create a Policy that has a trigger of Startup. Under "Files and Processes" in the Policy, use "Execute Command". You can then enter your command (without needing to add "sudo" to the front of it) and it will run at startup.
Thanks! exactly what I was looking for!
Already have an account? Login
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
Sorry, our virus scanner detected that this file isn't safe to download.
