https://helpx.adobe.com/security/products/flash-player/apsb15-14.html
As of now it's not posted in the auto update, so the auto update scripts will not work.. : (
C
C
Not unexpected. Unless my count is off, I believe the last 4-5 FlashPlayer releases have been put out and the Auto Update lagged behind, sometimes by several days. At first I thought this was accidental, but I believe now its on purpose. Seems like Adobe wants the bleeding edge users to download it first and confirm no issues before it shows up for the masses via their auto update mechanism.
IOW, they may be using the public for part of their testing of new versions.
Go to the bottom of this post. You'll find a script that works through versions.
https://jamfnation.jamfsoftware.com/discussion.html?id=7658
