WIndows JSS and a few questions
  • June 16, 2011
  • 4 replies
  • 32 views
Recently we moved our JSS to a Windows server due to resource limitations on the Mac Mini we had in place. I have two issues and can't seem to overcome them:
  1. I can not connect to the JSS using the JSS Setup Utility.
  2. Self Service to port 9006 is not functioning from external to the server or to localhost:9006
Did I miss something. I followed the docs to a T.
Server is server 2008 R2 Standard x64. 8GB of RAM
Thanks,
Shannon L Rico
Sr. Network Engineer
GISD
d: 972-487-3663
c: 214-882-3621
  • June 16, 2011
The JSS Utility uses SSH to connect first. If you don't have a SSH server on your Windows server, it will fail. You'll have to install a 3rd party SSH server as Windows doesn't ship with one. I'm not sure what could be the problem with Self Service.
Jack
  • June 16, 2011
We're running a Windows server based JSS as well. I was told the JSS Setup Utility was for Mac server based JSS and not to use it with the Windows server. FWIW. I'm contemplating moving it over to a Mac server.
Tom
  • June 16, 2011
I installed freesshd and can SSH with putty but JSS setup utility says invalid UN/PW
Thanks,
Shannon L Rico
GISD
d: 972-487-3663
c: 214-882-3621
Forum|alt.badge.img+20
  • June 16, 2011
I use MobaSSH.
Matt Lee
FNG Sr. IT Analyst / Desktop Architecture Team / Apple S.M.E / JAMF Casper Administrator
Fox Networks Group
matthew.lee at fox.com<mailto:matthew.lee at fox.com>
Need Help? Call the Help Desk at (310) 969-HELP (ext 24357) or online at http://itteam<http://itteam/>
Help Desk Hours: Mon-Fri, 6AM-6PM PST
