A guide to JSS Azure AD integration (LDAP + SSO)
  • Oct 26, 2017 12:50 PM UTC
  • 59 replies
  • 778 views
Show first post
DBrowning
  • Feb 21, 2023 3:20 PM UTC
This is already the case.
What attribute do you have set for Username within the Azure Ldap mapping?  I would assume you are using the same when trying to auth.
anverhousseini
For username there is "userPrincipalName" which should be the mail address which I'm also using in the authentication.
DBrowning
  • Feb 21, 2023 3:25 PM UTC
and to confirm if you do a test search for the email address it comes back with a user?
anverhousseini
Yes, this is working fine. We are already using the LDAP to fill the user and location inventory details with the SSO enrollment customization.
DBrowning
  • Feb 21, 2023 3:28 PM UTC
Do you have password hash sync enabled in Azure?
anverhousseini
No, the customer has cloud only accounts, no hybrid environment.
DBrowning
  • Feb 21, 2023 3:41 PM UTC
Still needs to be enabled from my understanding.
Link for cloud-only user accounts.
anverhousseini
Ok, I think that was the issue and also there was a setting called "LDAP Signing" or something. But it seems we need to reset the password for LDAP to work.
DBrowning
  • Feb 21, 2023 4:52 PM UTC
Yeah once the sync is enabled, a password change is needed.
