Activation Lock Bypass Codes Not Working
  • Jan 5, 2018 5:55 PM UTC
  • 30 replies
  • 833 views
Show first post
Yes that usually works. For this device it did not. I tried the unlock code (Manually typing in the long thing like 10 times incase i made a typo). Never went through.
Plugging into the PC just popped up the same activation lock, and yeah you can paste the unlock code in there, so you dont have to manually type it in, but it still didnt work. So with this device it was the only way.
  • Jul 14, 2021 6:15 PM UTC
Having the same issue. Usually works.
i talked to apple a few weeks ago and they have massively improved the system now. There is now a button that you can self serve remove the activation lock by going to school.apple.com and finding the device. There is now an activation lock removal button you can just click there. As long as the device is in apple school, it will work.
https://support.apple.com/en-ca/guide/apple-school-manager/axm812df1dd8/web
  • Oct 15, 2024 1:25 PM UTC
This worked for me with the device in Apple School Manager.
Thank you!
  • Oct 15, 2024 6:53 PM UTC
I used UnlockBoom. com services to remove the iCloud Activation lock from my iPhone 15 pro Max, and it worked very well.
