Allowing Air Drop & Handoff setting in JAMF Pro
  • May 12, 2023 12:19 PM UTC
  • 598 views
Hello all,
We allow our users to use AirDrop in our environment.
I know Ventura has changed from System Preferences to System Settings. They also seem to change the Air Drop setting. It was previously a setting by its self and is now bundled together with Handoff so its AirDrop and Handoff.
The problem is I can not get machines on Ventura to be discovered through Air Drop and the AirDrop and Handoff setting is grey out and says (These settings are controlled by a profile.)
My Config profile allows Airdrop in both Media and Sharing Services. I have also allowed Handoff through the Restrictions --> Functionality screen.
Even with those settings, I can not get AirDrop and Handoff to be configurable from the client side.
Any thoughts??
1 reply
AVmcclint
Forum|alt.badge.img+21
  • Jun 28, 2023 5:18 PM UTC
Nevermind, it does work on our Macs.
