Alternative solutions for deploying cert-based Wifi Authentication via Jamf Pro
  • Feb 5, 2024 7:50 PM UTC
  • 49 views
Hello All,
I'm researching other solutions to deploying cert-based WiFi authentication via Jamf Pro for our office Macs. I'm familiar with the AD CS connector, but our cyber security team will not open network traffic to ports 443, 8443, etc. I don't believe Jamf Pro provides a block of secure IPs that can be used, so we need to find an alternate solution.
What other solid solutions are available to us that will allow Jamf Pro to provide cert-based WiFi authentication?
1 reply
Ismere
  • Feb 6, 2024 9:26 AM UTC
we are authenticating into WiFi with the Certificates and are using it as an Login Windows conf so that users only have to put there credentials into the Mac once....
Technically you can define it in multpile ways. Refer to Apples Information on this Site: https://support.apple.com/en-gb/guide/deployment/depabc994b84/web
For your Problem with AD-CS connector and secure Trafic.... your AD-CS does not need to be on the same Server/Maschine with your JAMF-Server. So technically you can open up the ports for a specific Networkaddress.
