API - Creating a Smart Mobile Device Group Not Possible
Hi all,
I'm new to JAMF Pro and just wanted to confirm what I think I am seeing.
That  there is no api for creating smart mobile device groups, only static.
Can anyone confirm that my understanding is correct.
Thanks
Steven
Best answer by lukecharters
Classic API has it
Creates a new mobile device group by ID (jamf.com)
  • June 23, 2022
@lukecharters Thank you. I'm new to this and I missed it.
Just a related followup if I may.
Can the extended attributes for a device be part of the search criteria?
Yep, should just appear in the list once you've created the extension attribute. You may need to press show advanced criteria if it doesn't appear in the initial list.
