API scripting issue - delete empty usergroups (and classes)
Novice scripter trying to modify a script from github to delete all empty usergroups from Jamf. Currently getting line 26: syntax error near u'expected token `do
Eventually I want this script to also delete empty classes as well.
# Script to delete empty usergroups
jssUser="******" # Full JSS Admin Account
jssPass="******" # Password for the JSS Admin Account
index="0"
usergroups=()
echo $jssURL
IDs=`curl -sk -u $jssUser:$jssPass -H "Accept: text/xml" "https://******.jamfcloud.com/JSSResource/usergroups" -X GET`
size=`echo $IDs | xpath //user_groups/size | sed 's/<[^>]*>//g'`
echo $size " user groups will be scanned."
#Put the IDs into an array
while [ $index -lt ${size} ]
do
    index=$[$index+1]
    usergroups+=(`echo $IDs | xpath //user_groups/user_group[${index}]/id | sed 's/<[^>]*>//g'`)
    done
# Sort through each user ID individually and grep for IDs size
for i in "${usergroups[@]}"
do
    usergroup=`curl -sk -u $jssUser:$jssPass  -H "Accept: text/xml" "https://******.jamfcloud.com/JSSResource/usergroups/id/${i}" -X GET`
    groupsize=`echo $usergroup | xpath //user_group/users/size | grep id`
    # Delete users that meet our criteria
    if [[$groupsize -eq 0]] ; then
        echo "Deleting ${i}"
        curl -k -v -u $jssUser:$jssPass  -H "Accept: text/xml" "https://******.jamfcloud.com/JSSResource/usergroups/id/${i}" -X DELETE
done
  • 10 replies
  • August 20, 2018
Are you missing a second done to close off the if statements? I'd give that a go!
sdagley
  • 3540 replies
  • August 21, 2018
@MDMMan When posting scripts to Jamf Nation, please use leading and trailing triple backticks (```) to signify a code block.
As a handy tool for checking scripts, take a look at ShellCheck. It gives you interactive feedback on your script, so you could quickly try @connor's suggestion to see if that eliminated the syntax error.
  • 15 replies
  • August 21, 2018
@connor I have two DOs and two DONEs. I have one IF and one FI.
@sdagley Thanks for the backticks tip. It definitely makes the code block more readable. ShellCheck says what Connor said. I tried adding another done but it didn't make a difference. ShellCheck doesn't seem to be able to read the done for either do. It also doesn't like the While statement.
sdagley
  • 3540 replies
  • August 21, 2018
@MDMMan You need a space after the [[ and before the ]] on line 31 in the script as it currently reads above. Once you do that ShellCheck will have several additional suggestions.
  • 15 replies
  • August 21, 2018
Thanks. I have reworked the script based on shellcheck. Still getting errors. line 22: syntax error near unexpected token `do
It wants me to add additional double quotes that do not appear to be needed..
jssUser="****" # Full JSS Admin Account
jssPass="****" # Password for the JSS Admin Account
index="0"
usergroups=()
IDs=$(curl -sk -u $jssUser:$jssPass -H "Accept: text/xml" "https://****.jamfcloud.com/JSSResource/usergroups" -X GET)
size=$(echo $IDs | xpath //user_groups/size | sed 's/<[^>]*>//g')
while [ $index -lt $size ]
do
    index=$($index+1)
    usergroups+=( "$(echo "$IDs | xpath //user_groups/user_group[${index}]/id | sed 's/<[^>]*>//g')")" )
    echo $usergroups >>"/tmp/usergroups.txt"
    done
do
    usergroup=$(curl -sk -u $jssUser:$jssPass  -H "Accept: text/xml" "https://****.jamfcloud.com/JSSResource/usergroups/id/${i}" -X GET)
    groupsize="$(echo "$usergroup | xpath //user_group/users/size | grep id")"
    if [[ $groupsize -eq 0 ]] ; then
        curl -k -v -u $jssUser:$jssPass  -H "Accept: text/xml" "https://****.jamfcloud.com/JSSResource/usergroups/id/${i}" -X DELETE
done
sdagley
  • 3540 replies
  • August 21, 2018
@MDMMan ShellCheck isn't showing a syntax error for the most recent version of the script you've posted. What did you change from the version you're trying to run?
  • 15 replies
  • August 21, 2018
Here is the current version that is still returning the syntax error when running the script via terminal. line 22: syntax error near unexpected token `do
jssPass="*****" # Password for the JSS Admin Account
index="0"
usergroups=()
do
    index=$($index+1)
    usergroups+=( "$IDs | xpath //user_groups/user_group[${index}]/id | sed 's/<[^>]*>//g')" )
    done
do
    usergroup=$(curl -sk -u $jssUser:$jssPass  -H "Accept: text/xml" "https://*****.jamfcloud.com/JSSResource/usergroups/id/${i}" -X GET)
    groupsize="$usergroup | xpath //user_group/users/size | grep id"
done
Cookie policy
Cookie settings
