Apple Script to bash script - mount network volume
  • Mar 7, 2025 3:38 PM UTC
  • 5 replies
  • 155 views
Hello everyone,
Now when we have left our old eDirectory and are up en running with our Entra en AD I put together some Apple Scripts for mounting network volumes - home and shared. The scripts work okej but I think it would work even better if you made them as bash script instead. But I'm not good att bash at all. Maybe someone's willing to help me out? One of the scripts I've done look like follows:
set userName to short user name of (system info) set Share_Path to "smb://" & userName & "@our_server_address/home$/" & userName tell application "Finder" mount volume Share_Path open userName end tell
Thanks in advance,
Jonas
Best answer by Valcovish
Hey Jonas,
You’re right—using a Bash script for this is a cleaner approach, especially when deploying via Jamf. Below is a Bash script that replicates your AppleScript functionality. It dynamically retrieves the currently logged-in user and mounts the SMB share accordingly:
# Get the currently logged-in user
currentUser=$(stat -f%Su /dev/console)
# Define the SMB share path
serverAddress="our_server_address"
sharePath="smb://$serverAddress/homes/$currentUser"
# Check if the share is already mounted
if mount | grep "$sharePath" > /dev/null; then
    echo "Share already mounted."
# Create mount point if it doesn't exist
mountPoint="/Volumes/$currentUser"
if [ ! -d "$mountPoint" ]; then
    mkdir -p "$mountPoint"
# Mount the SMB share
osascript -e "try" -e "mount volume \\"$sharePath\\"" -e "end try"
# Verify if the mount was successful
if mount | grep "$serverAddress"; then
    echo "Successfully mounted $sharePath"
    echo "Failed to mount $sharePath"
    exit 1
Explanation:
  • •Retrieves the currently logged-in user with stat -f%Su /dev/console
  • •Constructs the SMB path dynamically
  • •Checks if the share is already mounted before proceeding
  • •Creates a mount point if it doesn’t exist
  • •Uses osascript to mount the volume via Finder, avoiding password prompts when possible
  • •Verifies if the mount was successful
This should work seamlessly in Jamf deployments. Let me know if you need any tweaks!
junjishimazaki
This is a bash script I deploy from Jamf to mount DFS shares
# Get current logged in user
curUser="$(stat -f"%Su" /dev/console)"
# Mount the drive
mount_script=`/usr/bin/osascript > /dev/null << EOT
delay 5
mount volume "smb://PATH_TO_SHARE"
end tell
EOT`
echo "Opening Network shared drive..."
# open network drive in Finder
sudo -u $curUser open /Volumes/PATH_TO_SHARE/
If your file share requires authentication, then the user will get prompted to login
  • Mar 10, 2025 7:40 AM UTC
# Mount the drive
delay 5
end tell
EOT`
Thanks @junjishimazaki,
Like a mention before, I'm not so good at this with bash. :) I've tried to edit the script you shared a bit to fit our needs but I don't think I get it really right. This is what I'm trying to accomplish.
#!/bin/sh # Get current logged in user curUser="$(stat -f"%Su" /dev/console)" # Mount the drive mount_script=`/usr/bin/osascript > /dev/null << EOT delay 5 set userName to short user name of (system info) set sharePath to "smb://" & userName & "our_server_address/home$/" & userName tell application "Finder" mount volume sharePath end tell EOT` echo "Opening Network shared drive..." # open network drive in Finder sudo -u $curUser open /Volumes/$curUser/ exit 0
Maybe it's not necessary to declare variable for both bash and apple script? :)
Valcovish
  • Mar 10, 2025 3:01 PM UTC
Hey Jonas,
    exit 1
Explanation:
  • Mar 11, 2025 1:10 PM UTC
Hey Jonas,
    exit 1
Explanation:
Thank you very much @Valcovish,
This script just works and very good as well. Now when I've been testing a lot, it's easy to understand the code as well. 😊👍
Valcovish
  • Mar 11, 2025 2:26 PM UTC
Glad to hear that, please consider marking the topic as resolved.
