Automate/Script for Building / Department
Looking for a way to use a script, or some other method, to bulk set the Building & Department for IOS devices. I have 440 iPads being delivered in a couple of weeks going to 5 buildings scattered throughout the state.
Thank you.
Kevin Sinclair
Best answer by talkingmoose
A couple of ideas, but they depend on whether the devices are enrolled prior to setting the information or after.
You can use a mass action to set Building and Department for devices that already exist in your Jamf Pro server. You'll just need a clever way to identify them. Maybe search by IP range or model.
Alternatively (and this will work for not-yet-enrolled as well as enrolled devices), you can take advantage of Settings > Global Management > Inventory Preload. Download the template, populate the serial numbers of the devices and then set the Building.
Be aware that if you use Inventory Preload, the data you provide will overwrite any changes you make to the device records with each inventory update. If you want to be able to make changes later, you'll need to delete the preloaded data to keep it from overwriting.
  • March 30, 2022
Sounds like you could use the MUT for this. https://apps.apple.com/us/app/mut/id1133234759?mt=12
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • March 30, 2022
  • March 31, 2022
Thank you for the response, I think I can make either of those solutions work.
  • March 31, 2022
Unfortunately that app requires a Mac, which I do not have. My organization uses Windows PCs. Thank you for the suggestion though.
