Block SMB / AFP connections
Hi all
I've searched high and low, but have been unable to find anything on this. We're looking to block the ability for devices to connect / mount shares using SMB / AFP.
Has anyone done this, has a script or can point me in the right direction?
Cheers!
Best answer by brockwalters
https://community.jamf.com/t5/jamf-pro/disable-smb-mounting-from-the-client-side/m-p/44303
https://apple.stackexchange.com/questions/380010/how-can-i-block-all-ports-except-443-on-macos-catalina
Not sure if either of those will suit your needs but that's where I would start...
  • August 4, 2022
When positing code please use the >_ icon in the toolbar above the text entry field to format it correctly (or just add a line of 3 backticks ``` before and after the code block) VWCredit.com
brockwalters
  • August 4, 2022
  • August 8, 2022
SMB is a fabric protocol that is used by Software-defined Data Center (SDDC) computing technologies, such as Storage Spaces Direct, Storage Replica. Apple Filing Protocol (AFP) AFP is a network file control protocol system specifically designed for Mac-based platforms.
Tellthebell.com
